Re: Farmall C Rockshaft Arm - Pins?
Posted by gene bender on September 23, 2012 at 13:00:21 from (67.55.226.162):
In Reply to: Farmall C Rockshaft Arm - Pins? posted by Keven McNeice on September 23, 2012 at 10:46:43:
You can make those pins out of a bolt. Cut off the end for correct length. Now chuck the end in your drill press and turn on the drill and use a grinder to shape the head round and thin enough for clearence. You can make the holders with a piece of metal and the pin that holds them. I can make them if you want.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
