Re: Timing check on Farmall A
Posted by teddy52food on September 23, 2012 at 15:01:28 from (184.94.175.179):
In Reply to: Timing check on Farmall A posted by charlie M on September 23, 2012 at 14:46:55:
It is there, just hard to see. You may have to clean the flywheel to find it. It will be in line with a pressure plate bolt.
