Farmall cylinder
Posted by Pgarrett on September 23, 2012 at 15:31:47 from (166.147.104.28):
Going to mow some ragweed and the cyl . That raises the sickle mower on my H is leaking pretty bad. Can you still get piston seals for those old farmall cylinders?
