Re: NOISE IN TRAN OF FARMALL SUPER C
Posted by Harold H on September 23, 2012 at 17:27:40 from (12.23.230.67):
In Reply to: NOISE IN TRAN OF FARMALL SUPER C posted by Fred smith on September 21, 2012 at 03:59:58:
If you are in an area that never gets cold you could use 140w and it woulod probably quite it down a little. First I would check, after the tractor has been sitting severl days, open the drain plug and see if any water runs out. If it does, this could affect it as the water dilutes the oil to a thinner viscosity than it was. If so let all of the water drain then stop the plug and top off to proper level with new 90w or 140w if you are in warm area. Definirtely do not use 140 if you plan on operating tractor when it is cold weather.
Harold H
