Re: Ignition
Posted by oldtanker on September 23, 2012 at 19:45:27 from (66.228.255.239):
In Reply to: Ignition posted by Ellis Kinney on September 23, 2012 at 18:04:36:
I would look for the Autolite or AC plug to replace that.
If you used the stock gap that coil isn't going to give you much if anymore spark. As the coil discharges it's spark it builds voltage until the resistance of the gap is overcome. If that resistance is say 12,000 volts that's all it's going to make. Just because the coil can make more, like say 40,000 doesn't mean it will.
Don't expect a big HP boost. On that HP engine you may see oh around 2 HP max. Don't get me wrong. I love IE and installed on my 8N as a test figuring that if I like it I will do the M and the other 8N. I do love how it starts! WOW! Always catches on the 2nd revolution and stays running. Doesn't start, stall then restart.
Rick
