Re: C123 vs. C135
Posted by CNKS on September 24, 2012 at 05:33:56 from (216.144.104.128):
In Reply to: C123 vs. C135 posted by dgerth on September 23, 2012 at 19:46:20:
A true 123 has a block number of 354898 R--. 3.25 sleeves will fit without boring giving cu in of 132.7, you can use step head pistons giving more power than the original C123. That is the simplest. C153 is essentially a C135 without sleeves.
