Re: Ignition
Posted by oldtanker on September 24, 2012 at 06:38:19 from (66.228.255.239):
In Reply to: Ignition posted by gearheadbill on September 24, 2012 at 04:53:18:
Like John said there is no need to set the gap bigger. I really wouldn't mess with it unless you are going to run race fuel or upping the compression. On the plugs, when they go bad I'd change brands. You can research it on the net but there are better plugs out there in the same price range.
One of the biggest advantages to IE is it eliminates point float at high RPM's. Much higher than an M is going to run. I like it because it's pretty much maintenance free.
Rick
