Re: crank c123
Posted by El Toro on September 24, 2012 at 07:23:56 from (108.3.143.30):
In Reply to: crank c123 posted by tuckaway on September 24, 2012 at 06:54:10:
I would pull that crankshaft and have it measured for wear. The main bearings may be too tight. You could loosen the main bearing caps to see if that helps. Buy your new bearings from the auto machine shop that measure's your crankshaft. The crankshaft may need a polishing. They won't grind it undersize unless it needs it. Hal
