Re: Gear ratios
Posted by WellWorn on September 24, 2012 at 08:30:06 from (69.95.14.14):
In Reply to: Gear ratios posted by Bouncer on September 23, 2012 at 17:32:40:
Buddy Woodson said: (quoted from post at 01:32:40 09/24/12) Did all A's, SA's and B's use the same gear ratios?
Hi Buddy,
According to the parts book, the A and SA (and C and SC) had the same transmission and final drive gearing. Even the AV (Hi-Clear A) had the same gearing, which made it a bit faster on ground than it's shorter brother. I'm not an expert and could be wrong, but the B was in all probability mechanically the same as well.
This post was edited by WellWorn at 08:34:55 09/24/12.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
