Re: fuel line
Posted by Lmack on September 24, 2012 at 08:37:38 from (24.131.58.167):
In Reply to: fuel line posted by j strickland on September 23, 2012 at 17:21:50:
As 504 says use steel break line. You will not be able to tell the difference between original stock and the new line. FYI do not put a loop in the line. It could cause problems since these systems are gravity systems and the loop can cause an air block. No loop was used in the original design. Keep it sloping down all the way from the sediment bowl to the carburetor. DO NOT INSTALL AN IN-LINE FUEL FILTER!
