Re: crank c123
Posted by gene bender on September 24, 2012 at 10:49:15 from (67.55.227.213):
In Reply to: crank c123 posted by tuckaway on September 24, 2012 at 06:54:10:
Pull the engine and remove the bearing caps and then you will know why its stuck. You cannot remove crank until the engine is removed. If it was stuck you needed to remove the crank anyway.Pull the engine and tear it down.
