Re: Valve stem on H tires
Posted by Red Mercury on September 24, 2012 at 18:57:33 from (204.112.37.125):
In Reply to: Valve stem on H tires posted by j hakenwerth on September 23, 2012 at 16:00:20:
I prefer them on the outside. If the tractor is ever going to sit unattended with livestock then they are better off on the inside. We have had cattle rub valve stems off.
