Re: Early Cub
Posted by mkirsch on September 25, 2012 at 05:22:39 from (64.80.110.75):
In Reply to: Early Cub posted by Sammy in Kansas on September 24, 2012 at 19:52:58:
A Cub may be a small tractor but it will still hurt if it falls on you. You will have the front end suspended in the air with nothing underneath it for a while, so be careful.
The pivot pin should push out easily, because it's usually worn and well lubricated from oil leaking out of the steering gearbox.
None of it is rocket science. Lift the front, remove the pin, roll the old front end out, roll the new one in, and replace the pin. Drop the front, and drive away.
