Re: H4 I/H Magneto
Posted by Bob M on September 25, 2012 at 11:35:47 from (74.67.191.50):
In Reply to: H4 I/H Magneto posted by Leonard Dacus on September 25, 2012 at 11:04:14:
Several possibilities caused by an accidental contact with the battery:
1 - Breaker point contacts got burned. Try dressing with a point file then resetting the point gap to 0.013.
2 - Coil primary has been fried. Check with an ohmmeter: A good coil will show a few tenths of an ohm between the breaker points insulated contact and ground with the points open. If the meter shows open circuit it's time for a new coil.
3 - The magneto magnet became demagnetized. Repair is best left to a good magneto rebuilder.
As for testing a condenser, disconnect the wire from the condenser to the breaker points. Now take you ohmmeter, set it to it's highest scale then take a reading between the condenser's lead and case. A good condenser should initially show relatively low resistance which gradually increases over several seconds to several megohms.
If the meter shows infinite resistance (open) or 0 ohms (short circuit) the condenser is no good.
