Re: Difference
Posted by jimb2 on September 25, 2012 at 17:08:26 from (99.241.38.122):
In Reply to: Difference posted by rustidiot on September 25, 2012 at 14:09:25:
Hi, 2444 and 444 have the same BD-154 Diesel engine unless you have a rare gas version. The block is slightly different between the 2444 and 444 but the water pump should be same.
I looked up in CNH Parts:
Water Pump 424,2424,444 and 2444
3042304R91 BEARING, water pump spindle
704216R4 BODY, water pump
B414D,3414,3444 and 7000 Forklift:
The bearing is usually the part that fails and allows coolant to leak. The bearing can be changed if you have access to a press but otherwise the casting body will break. Years ago when we had B414D,434 and 384, our local IH dealer carried re-manufactured water pumps.
JimB
