Posted by D Slater on September 25, 2012 at 17:08:51 from (184.15.50.155):
In Reply to: Re: farmall 350 parts posted by andrew branagh on September 25, 2012 at 16:20:43:
Possible for a 300 or a 350 tractor to have that serial number. Maybe the simplest way to tell you is to look at the lever on the left side of the tractor center housing that the rod from the t/a handle moves. Should find a number on it. If the first 3 numbers is 360 its a 300, if the first 3 are 365 its a 350.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
