Posted by rhtx55 on September 25, 2012 at 17:49:33 from (207.119.56.149):
In Reply to: farmall 350 parts posted by andrew branagh on September 25, 2012 at 14:40:19:
Look on the right hand side just above the oil filter, on the engine block will be a raised stamp. If it's C-169 the tractor is a 300, if it's C-175 it's a 350.
This tractor does have the early style fast hitch with the small cylinder on the side, this was common on the early 300 tractors ( 1954 through Nov 1955) when the 350 was introduced they came out with the later "traction control" fast hitch that only had the large cylinder in the rear and the big handle to the left of the operator.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
