Re: farmall 350 parts
Posted by Brendon-KS on September 25, 2012 at 18:08:57 from (63.245.190.37):
In Reply to: Re: farmall 350 parts posted by 60 acre hillside on September 25, 2012 at 16:53:16:
Basic engineering principles prove the benefits of wide front ends when talking about stability. Raising the front "tipping point" by several feet as done with a wide front does the same for sideways stability as lowering the center of gravity by 6 inches or more (depends on actual tractor geometry). The farther forward the CG is the more benefit it offers. This is why wide front ends add a lot of stability when a loader is involved.
That said, what you say about being careful holds true regardless. ANY tractor can tip over under the wrong set of circumstances.
