Posted by D Slater on September 25, 2012 at 20:33:51 from (184.15.50.155):
In Reply to: farmall 350 or 300? posted by andrew branagh on September 25, 2012 at 20:05:08:
Lots of those tractors have all the paint gone from the serial tags that said the model. Both tags are in the same place. Both tractors started serial numbers at 501 and both went higher than the serial # you posted. So you go by date codes and things found on the tractor.
I posted below one way to tell. Other things, 300 key start, 350 key and starter button. Rear light right side 300, left side 350. Don't see any holes in the steering support or hydraulics cover to change valves from single to double acting like a 350 would have. Clutch pedal on a 300 has a adjustable stop bolt at the very bottom. 350 has none. 300 used a keyed steering wheel. 350 splined. 300 169 on engine block. 350 175 on block. Most of the 300 and all 350 used the block cast # posted. My moneys on it being a 300.
Also the 360486R2 # is the casting # of the center housing. Before 300 production ended they were up to a higher suffix than R2. 350 will mostly be R5. Tractor serial would be a 1955 300.
Only a little over half as many farmall 350 tractors were made as was farmall 300 tractors. Both don't seem to be real high on the collection list of some collectors though.
This post was edited by D Slater at 20:52:15 09/25/12.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
