Re: farmall sm
Posted by mkirsch on September 26, 2012 at 06:02:48 from (64.80.110.74):
In Reply to: farmall sm posted by tom thorn on September 25, 2012 at 15:34:25:
Compression in PSI as in a compression check, or compression RATIO?
In PSI, more is better and consistent across all cylinders is more desirable than a high compression.
IIRC you need 90PSI for an engine to run decent.
>100PSI is an engine with a lot of life left in it.
>125PSI is a good strong engine.
