Re: Reinstalling motor on H
Posted by glennster on September 27, 2012 at 08:42:31 from (75.57.143.173):
In Reply to: Reinstalling motor on H posted by BruceS. on September 27, 2012 at 07:16:47:
to help line the motor up with the clutch housing, get some long bolts that fit the holes, cut the heads off the bolts and use a hacksaw and cut a slot in the cut off end. (that way you can use a screwdriver to remove them.) screw the bolts into the clutch housing, then when you go to slide the motor back in, they will help to hold and align the motor with the clutch housing. once it slides together, remove the temporary studs one at a time and replace with the correct bolts. usually 4 bolts work good at the holes where the frame rails bolt to.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
