Look at Delco generator images, then Delco Alternator Images Decide what you actually have. If alternator, it is 99.5 times of 100 a Negative ground. If it is a gen, it can be either pos or neg and can be setup to be either with no parts changes. Let us know. If it is an alt. And it was hooked up negative ground (as it is supposed to be) and it smokes when hooked up and is switched to start, (and stays smoking till the bat terminal is disconnected) the starter relay may be bad. If the alt was a problem, it would smoke as soon as the battery was connected. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
