Re: Nother question for John T
Posted by teddy52food on September 27, 2012 at 17:57:44 from (184.94.175.179):
In Reply to: Nother question for John T posted by Ellis Kinney on September 27, 2012 at 14:21:34:
What will it charge if you ground the field? Is the belt tight? What is the voltage when it is charging 5 amps? That regulator may need to be set up a little. If it quits charging at high RPM's, the brushes may be getting short or the commutator is dirty or oily or out of round.
