Re: Nother question for John T
Posted by Ellis Kinney on September 27, 2012 at 19:09:21 from (74.139.12.167):
In Reply to: Nother question for John T posted by Ellis Kinney on September 27, 2012 at 14:21:34:
Belt is adjusted properly and gen. has approximately 60 hrs on it. I don't want to ruin the new regulator by running tests on it. I don't know how to set up a regulator. Ellis
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
