Re: Lifting Power of Touch Control?
Posted by mkirsch on September 27, 2012 at 19:17:41 from (67.253.161.186):
In Reply to: Lifting Power of Touch Control? posted by DaveK(IN) on September 27, 2012 at 15:47:04:
Keep in mind the farther out you go on that jib, the lower the lifting capacity. 300lbs is back at the end of the arm that lifts the plow. Your crane arm is 2-3 times as long as the plow lift arm. That puts it down around 100lbs.
