Hey John T - The original, stock 6 volt starter and inertia (Bendix) drive are still on my Super M. It was my first alternator conversion - therefore it has survived on 12 volts for 30+ years now.
The only part I've had to replace was the commutator end plate. The original die cast (pot metal) plate cracked into several pieces - I presume from repeated impact reactions by the armature as the bendix spins out. The replacement commutator plate is stamped steel and is holding up fine.
As you suggest I use a smallish, 525 CCA battery in an attempt to limit starter inrush current. The tractor still has stock #0 AWG battery cables however.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
