Re: 806 Moisture in Hydraulic/Tansmission fluid
Posted by Dieseltech on September 28, 2012 at 10:54:19 from (75.146.127.110):
In Reply to: 806 Moisture in Hydraulic/Tansmission fluid posted by Bob3 Martin on September 28, 2012 at 07:46:59:
Have never tried this, but I wonder if tractor trans oil could be reclaimed by heating the oil in an open top barrel over time to about 250 degrees to boil out the water. I have the same trouble with older tractors that don't get used much, but sit under a lean-to on south side of the barn. Has anyone tried this since oil is getting higher in price?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
