Some regulators were made to replace the cut-out and then used that resistor on the field terminal but you did not use the wire going to the 4 pos sw. What is the Delce Remy # on the generator if its on an H should be 1100501,523 the Delce-Remy gens 1101423,355 were the three brush type and take a different reg. You need to start with what gen you have. Most guys at the counter either dont know or their book is wrong happens all the time so start with the gen# remember you have a pos ground.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
