Re: what kind of coil for a 300?
Posted by Bob M on September 28, 2012 at 14:07:57 from (74.67.191.50):
In Reply to: what kind of coil for a 300? posted by Zachary Hoyt on September 28, 2012 at 13:30:32:
Zach - Depends whether if your 300 is 6 or 12 volts. Also if 12 volts, whether it has a ballast resistor.
If 6 volts, or 12 volts WITH a ballast resistor, NAPA #IC7SB is good.
If 12 volts WITHOUT an external resistor then use a #IC10SP.
Either will cost about $20 - $25. If you don't have a NAPA nearby, most any auto parts store will stock equivalent coils.
If you are a stickler for originality, OEM style coils are available. But you are gonna pay a lot more.
