Re: Still the voltage regulator
Posted by Ellis Kinney on September 28, 2012 at 14:17:11 from (74.139.12.167):
In Reply to: Still the voltage regulator posted by Ellis Kinney on September 28, 2012 at 12:46:03:
Thanks for your ideas troops, what you are saying makes sense. I used the tractor for about an hour mowing this afternoon and it started after I shut it off, and that is an improvement so I guess it is charging enough not to drain the battery. I also bought a 2 gauge longer ground cable and ran it directly to the starter. Does it ruin stuff to use the FLD ground test permanently? Ellis
