Re: steering shaft removal 1950 super a
Posted by gene bender on September 29, 2012 at 02:42:53 from (67.55.227.68):
In Reply to: steering shaft removal 1950 super a posted by AngeloB_1973 on September 28, 2012 at 20:10:42:
Just like Srumper says remove the steering wheel and it will screw rite out the end. Before removing put the castle nut back on tight then by turning the steering wheel check how much end play the shaft has indicating a bad bearing on the shaft. The steering shaft should not have any end play when turning steering wheel back and forth.
