Four extra lights eh? I hope you used a relay to feed power to them. The electrical system and wiring on these old tractors is not adequate for even the factory installed lights. Battery connection on light switch frequently overheats, corrodes and makes for a bad connection.
The factory generator was IIRC only 25 amps. Five factory installed lights plus the ignition is about 20 amps, so not much left to run extra lights. Turning on the lights could pull down the battery voltage enough to where the ignition quits.
If not already done, you need to get this tractor converted to a high output alternator (three wire) along with some heavier duty wiring.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
