If the noise is in all gears except 5th, itcould be a chipped or broken tooth in the constant mesh gear set. (easily seen with the belt pulley (or pulley blanking plate) removed). If it is in all gears, it could be a front drive coupling failure (outside the trans) that can be fixed pretty easily if the belly pump is removed. If it is in only one gear, the issue is probably a chipped or broken tooth on that set of gears. I would not run it in the gears it happens. Actually it is diagnose first then decide. Broken teeth lead to disaster. Pulling loads make it have a shorter timeline to disaster. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
