Re: Farmall 300 gas tractor - oil in water system
Posted by Janicholson on September 29, 2012 at 14:20:17 from (96.24.99.126):
In Reply to: Farmall 300 gas tractor - oil in water system posted by Melvin Shaw on September 29, 2012 at 13:50:41:
Though most likely a head gasket, any internal oil gallery that has a crack that passes into the waterjacket could do it. The passage to the rockers would be the location of that, but go for the gasket. Jim
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
