Re: Farmall 300 gas tractor - oil in water system
Posted by D Slater on September 29, 2012 at 15:22:54 from (184.15.50.155):
In Reply to: Farmall 300 gas tractor - oil in water system posted by Melvin Shaw on September 29, 2012 at 13:50:41:
Is this a ongoing problem or something you just noticed? If the coolant pump is overgreased the coolant can look oily. Only other way I can think of is a leak on the pressure side of a oil passage. Like a crack in a oil passage or the oil hole through the head gasket to the head leaking. Most times after the engine is shut down and there's no oil pressure in the system coolant will leak into the oil if the above is the case. Maybe a crack in the rocker arm oil passage near the top of the head could leak oil and there not be enough coolant pressure that high to go back. Maybe other places, especially if the pressure cap on the radiator doesn't work.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
