Re: 806 pto turns on sometimes while driving.
Posted by mazemeister on September 29, 2012 at 16:23:01 from (24.187.98.163):
In Reply to: 806 pto turns on sometimes while driving. posted by Daniel Chestnut on September 29, 2012 at 12:50:09:
check the control valve adjustment. there is a "feather" position with one pressure setting and "full on" with another... sounds like when the handle is "off" maybe there is just a little pressure getting to the clutch pack?
except there is a spring that holds the valve "off". hmmm... the brakes are spring applied, hydraulic removed, no adjustment.
maybe the brakes are weak? try this, with the tractor off and nothing hooked up, try twisting the pto shaft with your hand. your hand shouldn't be strong enough.
just brainstorming...
