Posted by Janicholson on September 29, 2012 at 17:10:03 from (96.24.99.126):
In Reply to: Shimmy in front of SH posted by Va Gasman on September 29, 2012 at 17:00:42:
No. that bearing needs to be stationary where it is. Moving it in or out might help a little for a little while. (as will the shim under the gear) these tactics move the point of contact to unworn places on the gear and worm. They don't usually last very long because the wear pattern is now concentrated on a much smaller slice of steel. If all play is taken out of the U joints, the replacement of the gear, the replacement of the bolster shaft bushings, and thrust bearing, and resurfacing of the shaft are the real deal answer. If it works for a while, all is good. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
