Re: 1930 Farmall Regular
Posted by Nebraska Cowman on September 30, 2012 at 04:56:50 from (98.127.37.225):
In Reply to: 1930 Farmall Regular posted by Jerry Claborn on September 29, 2012 at 18:18:50:
The old E4 magnetos with the open impulse dog are the worst. You have to reset the pawl and if it trys to start and then does not the impulse must be reset again. If you do not hear the impulse click every time you better stop cranking. Yes, use up strokes.
