M governor fixed
Posted by EP on September 30, 2012 at 05:50:12 from (70.192.13.241):
Just a follow up post about worn gov. pins,weights and carrier.I ended up drilling the weights to 19/64 then reaming to 5/16 for a smooth finish,and drilled the carrier to 5/16.then used a 5/16 hardened pin to go through and put a small spot weld on each end to secure it.Everything was nice and tight.Started it up and now it works like a charm.Thank
Eric
