Re: Farmall 450 wiring question- (reputation at stake!)
Posted by Janicholson on September 30, 2012 at 12:55:33 from (96.24.99.126):
In Reply to: Farmall 450 wiring question- (reputation at stake!) posted by P and R Pete on September 30, 2012 at 12:35:32:
The wire from the left side of the push button, coming from the ign switch should be hooked to the other side of the start push button. There cannot be a second wire going to the coil unless it comes from a second small terminal on the relay labeled "I" . If only one terminal, the wire to the coil should not be used. The coil is wired backwards, Negative ground should have the Negative post to distributor. Jim.
