Re: Farmall Super MTA Timing
Posted by The Red on September 30, 2012 at 13:00:41 from (69.246.205.0):
In Reply to: Farmall Super MTA Timing posted by Brady Miller on September 30, 2012 at 11:41:25:
Brady I have a couple of Hs and Ms but I don't think anything is different on the Super. Get number one piston on top dead center on the compression stroke. Leave the rotor on the distributor and see if it is pointing to the number one post on the cap. If not, rotate the distributor body until they line up. If you cannot turn the body far enough, pull the distributor out and rotate the gear a bit and stick it back in. If you have the vertical Delco Remy distributor, you can turn that easily.
