Re: Farmall 450 wiring question- (reputation at stake!)
Posted by P and R Pete on September 30, 2012 at 13:43:00 from (173.86.14.68):
In Reply to: Farmall 450 wiring question- (reputation at stake!) posted by P and R Pete on September 30, 2012 at 12:35:32:
Mr. Nicholson, I appreciate your help. I'll swap the coil terminals, and the wire from the ignition switch to the push-button.
Maybe I waylaid you- I have a ballast resistor also, and Mr. Brillman had two wires going to the coil, one directly from the solenoid magnet, and the other from the push-button-to-the-ballast-resistor-to-the-coil. I understood the solenoid-wire-to-the-coil to sidestep the ballast-reistor to provide extra power for starting. Does that make a difference in having two wires to the coil?
I amended my wiring diagram to reflect your changes and the ballast resistor. Is this now correct?
third party image
If not, once more, could you explain precisely which wire to the coil isn't needed, and could you explain where is the relay of which you spoke?
Thanks!
