350U distributor timing mark
Posted by linemechanic1 on September 30, 2012 at 18:09:46 from (69.86.135.178):
This message is a reply to an archived post by Janicholson on April 08, 2012 at 13:28:21.
The original subject was "Re: Farmall 300 Timing Marks".
I always thought that the first mark on the damper which passed under the pointer indicated some degrees BEFORE TDC. My 350U has 4 marks. I used the 1st to set valve lash and eyeballed the #1 on the cap so I"m sure I could have been off some. It did start within a couple of seconds (after new rings, valves, rod bearings, etc), so I couldn"t be TOO far off. Should I use a timing light? And which mark should I go for?
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
