Re: F-20 Engine rebuild questions
Posted by rustred on September 30, 2012 at 22:23:32 from (72.172.100.113):
In Reply to: F-20 Engine rebuild questions posted by Evan From IA on September 30, 2012 at 08:47:18:
when checking those brgs. , have you cleaned them good then oil them lightly then roll them over? any noticeable noise and replace them , but they may still out last you as they only run around 1000 rpm.
yes, you can reuse rod brgs. check and adjust with plastigage but stay on the maximum clearance end as they are already worn egg shaped.i check with plastige in three positions on crank.
