Re: F-20 Engine rebuild questions
Posted by SDE on October 01, 2012 at 05:44:11 from (174.124.53.135):
In Reply to: F-20 Engine rebuild questions posted by Evan From IA on September 30, 2012 at 08:47:18:
Rod cap bearings.
Use a magic marker or blue die and coat the bearing surface. Install them with enough shims removed that they are making contact with the crank journal. Rotate the crank enough for the contact areas to appear in the rod cap. Now you scrap material away from the contacted area and repeat the process until you have a bearing contact area that is close to being about 75% of the total bearing surface. Being a machinist, I made a shaft to fit the bearings onto before putting them in the enigine. I have only done this to one tractor and I still have not got it assembled enough to get it running. Check the archives for more info.
SDE
