Re: 1930 Farmall Regular
Posted by Jerry Claborn on October 01, 2012 at 07:19:00 from (68.191.106.221):
In Reply to: 1930 Farmall Regular posted by Jerry Claborn on September 29, 2012 at 18:18:50:
Should the magneto starter pawl be engaged (touching the magneto) or away from the magneto when cranking? My spark lever seems to be reversed from the pictures I have seen. The hole for the connecting rod is on the left side (next to the engine) when viewing the magneto from the rear. Should it be reversed? I could send pictures if someone would tell me how to do it.
