Re: PTO extension?
Posted by Wardner on October 01, 2012 at 08:18:31 from (4.154.249.16):
In Reply to: Re: PTO extension? posted by mkirsch on October 01, 2012 at 05:34:52:
The Prince Pump doesn't care about loads after. It has a continuous spline front to back. However, one should consider mounting the pump rigidly. It will be easier on the tractor PTO bearings.
I have two pumps and neither has a set screw in the splined bore coupling. If the splined shaft were bored, I suppose one could run a threaded rod through it and cut threads in the end of the tractor PTO. With a rigid mount pump, one could use a flanged bearing and set screw after the pump. A cheap way out is to cut a groove in the extension shaft for a snap ring.
third party image
third party image
third party image
third party image
