Re: Lifting Power of Touch Control?
Posted by JRSutton on October 01, 2012 at 12:16:11 from (75.130.109.233):
In Reply to: Lifting Power of Touch Control? posted by DaveK(IN) on September 27, 2012 at 15:47:04:
It's pretty cool looking.
Couldn't tell you what it'll lift, but I'd say you're certainly asking a lot of the bolt through the rockshaft. What grade bolt?
Whatever you pick up is going to have a bouncy ride - regardless of what the hydraulics can do, a few hundred pounds bouncing up and down on that thing, something's gonna give.
Just curious - what do you WANT to lift with it?
