like was said the 560 housing works on a SM. But if you want to use a M through 450 housing on a 560 the T/A handle piviot bracket won't bolt up the best unless some grinding is done. Like said 560 bearings work right in a SM axle housing. Think it was part way through 560 building that the axle housing wall thickness was increased on high crops. Don't remember if the same happened on regular farmalls.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
[More Ads]
