Re: Farmall M clutch pedal adjustment
Posted by mkirsch on October 01, 2012 at 12:54:18 from (64.80.110.74):
In Reply to: Farmall M clutch pedal adjustment posted by BigTone on October 01, 2012 at 12:21:01:
What do you mean by: Too high?
There is only one adjustment: Pedal free play. It will need to be adjusted after replacing the disk and pressure plate.
IIRC the distance is something like 1-3/8" measured flat across between the top of the platform and the arm of the pedal.
You adjust it using the threaded clevis on the clutch pedal. Remove the pin, loosen the lock nut, and turn the clevis in or out as needed.
